iPhone 6 compatible with PM
Mom100
Hello,  will an iPhone 6 that has not been updated in a while work with Public Mobile- currently with Bell and works
Mom100
Thank you - got set up on iPhone 6 with no update; downloaded the app on my iPhone 12 and set up from my phone - very pleased 😀😀
JayjayG
iPhone 6 are normally compatible with Nano Sim Cards, which Public Mobile uses. However, it is preferable to update your device,
 What size SIM card does an iPhone 6 use? | WhistleOut
DennyCrane
It will work, but it is not VoLTE compatible. Meaning you won't be able to use it for phone calls when roaming in the US. Aside from that it'll work fine though.
@Mom100
I would suggest you update the iOS 12.5.6 to prevent any issues but it should work fine.
hairbag1
@Mom100
until last spring, my son used an old iPhone 6 on PM network...worked ok. Just make certain the phone is unlocked from previous cell network.
hi @Mom100
yes, iPhone 6 will work here
