04-29-2026 09:00 PM
I am trying to get my mother’s account going, during eSIM activation it’s saying the iPhone 13 Pro is incompatible. The phone is eSIM compatible so I am wondering if your team is able to send me a QR code or another method by which the SIM can be added. When I try and endeavour support, and login, I see a white screen. So my only option is to use my account and write a note here. I can provide you her email but not in this public setting…
05-04-2026 07:57 AM
Thank you for the escalation! The customer is in contact with an agent.
05-03-2026 10:00 AM
Right and I’ve been messaging them since Thursday
05-03-2026 10:00 AM
I included screenshots of messages with that support I’ve been trying since Thursday
05-03-2026 09:59 AM
As you can see from the screenshots I can’t even get them to talk about the SIM card but ok I will send it again
05-03-2026 09:53 AM
Last week I asked question about an eSIM. On my mother’s account, unfortunately for some reason I couldn’t activate it on her iPhone 13 Pro it shows a white screen after tapping support so I can’t submit a ticket using her account. After making a post on here I was recommended to send a message to customer service. I have probably sent 20 messages back and forth, I have been repeating myself over and over and they won’t add the SIM card to the account. Like I don’t know what to do at this point they keep coming back with unrelated questions as if my messages aren’t being read. I’m really frustrated.
04-29-2026 11:48 PM
04-29-2026 09:03 PM - edited 04-29-2026 09:04 PM
You will need the assistance from a CS_Agent to help you activate the eSIM on her iPhone 13 Pro because it is eSIM compatible.
or
04-29-2026 09:02 PM
ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
04-29-2026 09:02 PM
hi @Jacobhere
yes, eSIM will work on iPhone 13, and PM agent can probably send you another eSIM to complete the activation
you can submit ticket by direct message:
