iOS 26 Upgrade
Luke1993
Hi,
Since the upgrade I did yesterday, my iPhone no longer makes 1-888 calls. I have the error message "you call cannot be completed as dialed"
When I try another phone, the call go thru. It's just mine...
1 REPLY 1
hi @Luke1993
this is not actually an iOS problem but a problem with PM.  But PM support agent can help to fix it
You will submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
