iMessage/data delay
02-04-2019 03:40 PM - edited 01-05-2022 06:36 AM
For a couple months I have been experiencing troubles with my 3G/LTE. My phone does not get iMessages or emails etc. instantly. I will get a bunch at a time, up to an hour after the sender had actually messaged me. When I receive the message it says ":7 minutes ago" for example even though it just popped up on my phone. It seems to only get messages when I fetch for them myself by opening and using my phone for other data related things, at that point it will retrieve all messages since I last did it.
Service
02-04-2019 05:11 PM
@agiles Couple of thoughts:
a) turn iMessages OFF then On a bit later to force a reset of Apple servers
b) confirm you have correct settings: Settings >> Messages >> iMessages ON, Send as SMS ON, MMS ON >> Send & Receive: should show your PM number and your Apple ID email.
c) cellular data & roaming must be ON
d) confirm your account shows a data plan under Plan & add-ons. Nothing visible there means you've used all your data allowance.
02-04-2019 04:00 PM - edited 02-04-2019 04:05 PM
I've merged these 2 threads because they are identical, but I have left the duplicate message intact, just in case you are subscribed both.
02-04-2019 03:41 PM
