text message delay, mms works properly
Mingh
My text message delayed by 10 to 30 minutes, both sending and receiving.  But MMS works properly.
2 REPLIES 2
slusagm
@Mingh reboot phone and reset network settings
If you are using Android, clear cache
And if still same, I would go as far as uninstall and reinstall the messaging app, which likely is Google Message
Chalupa_Batman
Hello @Mingh
Go into your Settings, find Network Settings and reset them and reboot your phone. See if that helps.
