04-06-2024
09:07 PM
04-06-2024
10:23 PM
computergeek541
Hi,
I just activated a new eSIM and ported my number over to Public. The number transferred and I can make phone calls and use my data. But when I try to add my phone number to my Apple ID so I can receive and send iMessages it says verification unsuccessful. And I can’t receive or sent any text messages either.
I have restarted my phone turned iMessage off and on. Is there anything I can do to fix this. I have messaged support but they are very slow to respond and it’s been almost 24 hours with no texting.
thanks
06-08-2024 04:32 PM
im also facing the same issue,can you guide me please ?
04-10-2024 07:05 PM
So just go to setting and phone and make sure your phone number has the 1 in front
04-10-2024 07:04 PM
Yes it was an easy fix for me. I just had to go to settings then phone and put a 1 in front of my phone number
04-09-2024 07:14 PM
were you able to figure this out? i am having the same issue
04-07-2024 05:27 PM
Same problem here. Transfered my number with public mobile yesterday with an esim and sms does not work today. Sms worked yesterday but I had the old sim still present. I removed it this morning and problems started. Iphonw indicates verification for my number and it start with +1
04-07-2024 01:11 PM
hi @Jennifernoyes if you can receive text from friends , it is an Apple issue not PM, please push Apple to investigate
04-07-2024 01:03 PM
Were you able to figure yours out?
04-07-2024 01:03 PM
No both Apple and PM are working on it.
04-07-2024 01:02 PM
And it didn’t work? Did you get it figured out?
04-07-2024 01:01 PM
Yes
04-07-2024 01:00 PM
Did you try putting a 1 in front of your number under the settings and phone
04-06-2024 10:55 PM
I have a call with Apple at 9pm I will let you know what they say. But I think it’s a PM issue.
04-06-2024 10:32 PM
Go to settings then phone and add a 1 under add my phone number. It worked for me.
04-06-2024 10:31 PM
Ok so I got mine to work all I had to do was go to settings then phone and add my phone number then I put a 1 in front of my number and it worked! I just needed to put the 1.
04-06-2024 10:05 PM
I submitted another ticket but I think they are closed now. And I can’t even go get a new plan because without being able to send or receive sms I can’t port my number
04-06-2024 10:04 PM
apple support won’t be able to help because I can’t send or receive text messages. It’s not really an iMessage issue. Without being able to send or receive sms you can’t set up iMessage.
04-06-2024 10:01 PM
@Madison10 - Please try contact Apple Support if CS_Agent doesn't resolve the issue - could be an issue on Apple's end.
04-06-2024 09:46 PM - edited 04-06-2024 09:47 PM
@Madison10 24 hours is to long
submit another ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
04-06-2024 09:20 PM
I have the same problem. Let me know if you have resolved the problem.
