i entered my wrong email address when i signed up
James-george
please help
wrong email entered i need to get into my account to enter my banking information
11 REPLIES 11
@James-george
you need to Contact Customer Support Agent by CS_Agentand Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and them will change for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to CSA,Click Here link,
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck..
 @jor123 : There is a backdoor method to change an email address. Note the word "an". That backdoor method changes the login id (email address) but not an internal email address that is used for things like the password reset. That second one is only changeable by the CSA's. So I guess they removed the option to avoid this confusion. And of course not wanting to spend the money to make it available.
At account activation, the entered email address is copied to two system locations.
t_p
@jor123 wrote:
Is there still no way to change your email address on your own in the self serve portal? (aside from the community portal one)
@jor123
Another solution (of sort) is to "adopt" the wrong email you used (if it has not been claimed by someone else) and keep using it for the self-serve login. But of course it may be too cumbersome to your liking.
jor123
Oh, interesting.
@jor123 You still need the CSA to change the account email.  The account used to allow it but it didn't work properly.
t_p
@jor123
No.I know it's complicated but it's the way it is with PM.
jor123
HALIMACS
@James-george
After the customer service agents update the correct email associated with your public mobile account, you will want to make sure the email address associated with your community account matches that of your public mobile account.
This way go forward requests made through the community site can be linked and verified.
To do this, tap on your avatar in the upper right and go down to my settings.
Triguy
You would need to submit a ticket to a CSA.
Here’s when and how to contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
t_p
@James-george wrote:
please help
@James-george
Contact CS to ask for help to change email:
or: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Edit: If you have several addresses in use, you could try and look for the welcome message sent by PM after your account activation. That would correspond to the correct email address used for login.
