Canada Post Strike
TomHollohan
I signed up for public mobile last week and Canada post went on strike the next day. Am I able to change my address to a street address to have my SIM sent to my daughter so I’m not waiting on it to arrive to start services?
Chalupa_Batman
Hello @TomHollohan
Since there have been no announcements yet about Public Mobile using courier services like last time, I'd suggest getting a SIM card this way so it's faster.  Plus, I wouldn't bother contacting customer service if the SIM card went out already last week, it's out of their control since it's sitting with Canada Post. Just purchase another SIM card and use it to finish the sign up. Then when you finally get the other SIM card, use it as a back up or refer a friend.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
Or find a Mobile Klinik near you. https://mobileklinik.ca/stores/
Yummy
Changing address to your daughter's place will not change anything as your SIM still has to be delivered by Canada Post.
slusagm
with Canada Post on strike, PM would be sending it via courier, so it might come faster than usual
but check with PM first.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Or if you don't want to wait, you can buy the PM sim card in person at Telus or Koodo store, or buy from Amazon.ca
