01-30-2021 04:21 PM - edited 01-05-2022 05:05 PM
02-10-2021 01:43 PM
Do you get the same error if you call one of the access numbers directly like +17785804001 vs just longpress of 1?
If the direct number works, press * when your greeting plays.
02-10-2021 11:30 AM
When I call my voicemail I get no response, no dial tone, nothing. Eventually an “unknown error “ message pops up
02-06-2021 03:17 PM
@SheilaHerrmann wrote:I thought I did. I get my own voice when I call in from another phone. I can leave a message but get error message when I want to retrieve messages
@SheilaHerrmann So when you call yourself and your greeting starts and you immediately press the * you get an error message?
02-06-2021 03:16 PM
02-06-2021 12:46 PM
If you ever want to access your voicemail from another line without ringing your own mobile number, here is a list of the known local access numbers across Canada:
02-06-2021 12:44 PM
@SheilaHerrmann wrote:When I try to retrieve a message I get “unknown error” message.
Then it looks like that your voicemail was not set up properly. Did you set up the voicemail when you first activated your account?
02-06-2021 12:37 PM
02-06-2021 11:49 AM
@SheilaHerrmann wrote:When I call from another phone I can hear my answer, but I can’t retrieve messages. When I hit ‘voicemail’ , it doesn’t react, no sound, no nothing
@SheilaHerrmann You need to press the * key when you hear your greeting, then follow the prompts.
02-06-2021 11:46 AM
If you are calling from another phone, press * . Then it will ask for your voicemail password.
https://www.publicmobile.ca/en/bc/get-help/articles/check-your-voicemail-messages
02-06-2021 11:45 AM - edited 02-06-2021 11:45 AM
@SheilaHerrmann : When your recording starts press the * key and then follow the prompts.
It sounds like your voicemail access number is not set properly in your phone. Pressing and holding the 1 key is the most common method to connect to voicemail. But the number needs to be something like +17785804001 or one of many across the country.
02-06-2021 11:39 AM
01-30-2021 04:39 PM
@SheilaHerrmann You can't dial into it? You can't set it up? You forgot the Pin? You can call your number from another phone, when it does to voicemail press * and follow the prompts.
01-30-2021 04:26 PM - edited 01-30-2021 04:30 PM
Hi @SheilaHerrmann ,
Try holding down the "1" on your phone dialer to call your voicemail.
Help article: https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
