how to create my account
riaganth15
7 REPLIES 7
@EAJ14_1924   did you try  asking it send the code to  your email  as well as sms ?
if you still cannot receive the code , open ticket with PM support and they can help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
EAJ14_1924
I got already my account it's work User Id and Password but when I log in today it won't work I'm code with 6 digits I don't receive any code then I reset password still not working screw up my account.
HALIMACS
For which account @riaganth15 ?
For self serve?
For cell service?
@riaganth15   if you are existing customer and you activated online yourself, you have a My Account created
If you activated in store some time ago, then yes, you might or might not have the My Account login setup yet
But either way, you can open a ticket with PM support using "Forgot Password" ticket type.  They will confirm and help to reset password or create a My Account for you based on the situation
hairbag1
@riaganth15
snipped from Help Files...
My Account Setup
When you activate your account with us, we’ll help set up a My Account for you at the same time. My Account is your one stop shop for everything Public Mobile, including making payments, purchasing plans or Add-ons, checking your upcoming bill, checking usage, changing personal information, or checking Rewards.
  • after creating your username (which must be an email address), password, , and PIN, you should keep this information in a safe place in case you forget.
  • You will need your email address and password to sign in to My Account.
  • Your PIN will be used when interacting with our Customer Support Agents for account support and when calling *611, which allows you to make basic account changes.
Added...
top of this page click Activate / Get Started / Account Set-up...then just fill in the blanks.
Make sure to write down and save passwords and pin numbers for future use.
dust2dust
Are you currently using services here? Or are you new and wanting to know how to get started?
