how to cancel sim order
mehtasahil840
I want to cancel sim order as I want it personally on the store
@mehtasahil840
If you ordered the PM SIM through the PM website. It is on it’s way to you and you won’t be able to cancel your order.
HALIMACS
@mehtasahil840
I don't believe you're able to cancel a SIM order once it's been fulfilled.
It's a good idea to have a spare SIM on hand in case yours becomes unusable or lost.
For the sake of $5 to $10, would recommend you keep a second one on hand.
It's also good in case you want to refer someone else to public mobile!!!
I don't think you can cancel SIM order (assuming you ordered from PM site).
you can try open a ticket with the mod:
To open a ticket with mod, click on the Bubble or directly at : https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Enter your question in SIMon. Follow the prompts until you reach the Contact Us button,
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
sunflowershine
@mehtasahil840 Where did you order? If you ordered from PM directly, you may need to contact the moderator.
