11-12-2018 10:01 PM - edited 01-05-2022 02:28 AM
11-12-2018 10:35 PM
Thank you everyone .the phone is working well right now after I activity the sim card 15 min
11-12-2018 10:17 PM - edited 11-12-2018 10:18 PM
The sim/phone should start working instantly considering everything goes well during the activation process.
11-12-2018 10:12 PM
If you are activating a new phone number, the phone should be working within 30 minutes up to one hour.
If you are porting a number from another provider, the phone should be ported within few hours if the other line is mobile line. If landline or VOIP port, it can take several days.
