Data usage limit
Belthor
Just
 a quick question for you what happens let say i have 1gig of data on my plan, can i go over that or does the data just stop/shutoff once the 1gig is reached?
You cant go over it, unless you have them do an early renewal of your plan.
Dunkman
@Belthor
This service is prepaid.  The data will just shut off.  No extra charges or overages.
mimmo
If you go over then data just stops until your next renewal, or if you get a data add-on.
When used up the add-on dissapears from selfserve overview page
NDesai
@Belthor Data will stop working completely once you use the available 1GB. You have an option to purchase a data add-on and it will stay in your account until you fully consume it.
