how do I change my email address that is registered?
Napaneekid
Napaneekid
Thanks!  I used the 2nd solution and sent a message. Awaiting reply.  Cheers!
Napaneekid
Thanks,  I used the second link.  The first system did not work.  Have sent msg.  Much appreciated!
@Napaneekid
only PM support can help to change your email address used for My Account
Pleae open ticket with them
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
HALIMACS
@Napaneekid
Simply ask the customer support agents to change it.   Only they can change the e-mail address used for self-serve login purposes.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
