hotspot connected devices no connecting to web
lunalightning
after trying editing etc and no luck chatbots advise worked here it is
Tap on the following
settings
system or system management
reset or reset options
reset network settings
enter password if needed
2 REPLIES 2
@Alexandf- I interpreted the post as simply describing his method of fixing the problem he had.
