holiday giveaways
featherland
Hi guys,
If I were to downgrade to another public mobile plan, would I still get to keep all the holiday giveaway long distance minutes and data features?
Thanks
HALIMACS
@featherland
Holiday and/or gifted, data and/or minutes, are yours to keep once they are showing in your account.
Special promotions for new activations which included data or minutes are usually tied to the plan type that was activated.  Those may or may not remain if plan changes are made after activation.
@featherland
Another thing to consider if you change plans these days.  Public mobile has change some of the plans to provincial wide calling.  For Canada wide calling, if you return to higher price plans later one, you may need to pay an extra $5 per month.  Something to consider.
https://productioncommunity.publicmobile.ca/t5/Announcements/New-Province-Wide-Calling-Plans-Limited...
@featherland wrote:
Hi guys,
Holiday giveaways are yours to keep until used up as long as the account is kept open at Public Mobile.
rliu1993
For sure. No worry
