03-13-2021 10:10 AM - edited 01-06-2022 02:17 AM
03-13-2021 01:56 PM
If the voicemail limits are a concern you can set your conditional call forwards to an alternative free voicemail provider such as youmail.com. You dont even need to install their app, and you will just get the voicemails emailed to you, with the message as a sound file attachment. The first 15 messages or so each month include voice-to-text transcription as well on the free tier.
03-13-2021 10:21 AM
@Coffeecoffer : And just for picky wording, voicemails are stored on a system server, not your phone. 🙂
03-13-2021 10:14 AM
@Coffeecoffer wrote:Hello,
How many voice mail messages can be stored on a cellphone till the mailbox is full?!
With my previous service provider I could only store 5 messages, 5 mins for every messages!
10 messages, 5 minutes each
Set up Voicemail (publicmobile.ca)
03-13-2021 10:14 AM - edited 03-13-2021 10:19 AM
I believe the limit is 10 voice mails
EDIT: Just to make a slight distinction - the device (itself) does not store the messages. The voicemail server stores it.
