09-13-2021 05:12 PM - edited 01-06-2022 03:30 AM
09-13-2021 07:18 PM
@douellet_90 did you ask your mom to confirm the answer ? ::)
it is possible it was key in wrong in the beginning. If so, you might want to open a ticket with PM to reset the logon credentials, then you can re-setup the security question.
Use the Chatbot on the lower right and then start by typing "Forgot Login credentials"
09-13-2021 05:59 PM
Wait out one hour. Clear your browser. Reboot your device and open one tab only in private/secret/incognito mode using Firefox, chrome, safari or edge work best.
Try again. If it still fails then contact customer support for a "password reset".
See below....
Open in chrome if using regular Google browser.
Open in private/secret/ incognito mode.
Type in public mobile account login.
09-13-2021 05:30 PM - edited 09-13-2021 05:33 PM
@douellet_90 wrote:where do i find this
Usually, in the browser (Chrome for ex.), there are 3 dots at the top. Clicking on it would show the option to use Incognito (also called InPrivate,etc..) mode.
09-13-2021 05:29 PM
windows
09-13-2021 05:29 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck....
09-13-2021 05:29 PM
am locked out right now yes my self to get in my account
09-13-2021 05:28 PM
Do you mean the Incognito Mode method....?
09-13-2021 05:27 PM
09-13-2021 05:27 PM
@douellet_90 wrote:trying to security question to verited my email help
The security question...are you trying to reset your Self Serve password?
OR, you do not remember which email is connected to your Self Serve, so you are trying different ones?
Do you have a secondary question? If so try again.
If you had to many failed attempts, system could have locked you out. Wait one hour and try again.
If still having issues ask CSA for help.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
09-13-2021 05:21 PM
@douellet_90 wrote:i tired to put my security question it says am wrong
when was my mother born ? I put the year it says its wrong
Try to use browser Incognito mode. There are often webpage issues lately.
09-13-2021 05:15 PM
