03-02-2018 03:47 PM - edited 01-04-2022 03:38 PM
04-14-2022 06:56 PM
hi @josh1 Login to My Account , check if the plan is Active. If it is, click Change SIM card and follow the steps there to request changing it to the new SIM card
04-14-2022 06:49 PM
Need help no service with new sim card
03-02-2018 04:04 PM - edited 03-02-2018 04:04 PM
@josh1 Keep the conversation/discussion on this same topic you created instead of creating new one for every reply.
03-02-2018 03:57 PM
ok ill check it out now
03-02-2018 03:56 PM
03-02-2018 03:53 PM
Try restarting your device. And give it a few hours for the network-side to catch up with the billing-side. If it still doesn't work within a day then you might have to contact the mods for assistance.
It would be helpful to know what kind of phone/device you have. And where you purchased it (ie: are you certain it's not carrier-locked), etc.
03-02-2018 03:51 PM
well i get deactivated cause public can't get back to people
03-02-2018 03:50 PM
You should send a message to the moderators for assistance. In your message, include all relevant information in your message, such as account number, PIN phone number, detailed problem description.
03-02-2018 03:43 PM
hi i tryed to change my plan on my acoount now i can't call text or anything
