hi i lost my sim card and something went wrong
mikemobile
when i input my new sim and requested email it gave error message this is new sim card xxxxxx--- but it was accepted the only problem is i got error message back to login
18 REPLIES 18
mikemobile
but i didnt put real sim number ---thanks
mikemobile
meow---all is good now
mikemobile
switched few numbers so it was not a worry for me if someone wants to stral it---but it was settled via moderator , it was easy but there was extra step for identification----when you change sim like i did i followed steps but got erropr page---but now all is great
mikemobile
i switched few numbers anyhow
mikemobile
never mind the mind reading just read properly as the moderator solved it----sorry to have not been clearer
JL9
Wouldnt put it past them!!
@mikemobile wrote:
so what if i posted a sim card its a fake number the point is i cannot change sim with platform when i add my email i get error message back to login
it looks like the SIM number you posted earlier was a real one.
@mikemobile wrote:
nothing was solved waiting for moderator obviosly people here are assume and are fixed on sim instead of reading anyhow waiting for moderator help
Keep monitor the Community inbox , the envelope on the top right.  PM support will reply you there.
It could be an easy fix for them, they can manually submit the SIM request for you
Gunner123
@mikemobile hi most of us don't have the mind reading course, maybe you should learn to explain yourself better!
mikemobile
mikemobile
never got logged in to begin with stop focusing on sim fool ---read the question and stop ass-U-ming your a fool just accept it
what you talking about go ahead try the sim fool as if i put ral sim
sum ass so much for your smart ass respons
mikemobile
look you are confused i never got in----the system gave me an error message when i wanted the email confirmation----it sent me back to login and never got no emails from public
mikemobile
not my real sim so if anyone wants to waste their time go ahead---so what if i posted a sim card its a fake number the point is i cannot change sim with platform when i add my email i get error message back to login
mikemobile
bro i did not swap nothing read properly man
@JL9
That is probably why he can’t get his SIM to work because someone hacked it.
@mikemobile
Click the down arrow in the circle bottom right of your user name.
Oracles could you please remove #
JL9
Yes ripe for those sim pirates out there.
@mikemobile   Please modify your post to remove your SIM card number, it is dangerous to post it here
Just click on the down arrow and Edit Message
Meow
Did you do swap SIM card? If yes, give it some time for system to refresh your account. Some 15-30 min, reboot and try again.
RossN
@mikemobile hi so are you saying you where in your self serve account and successfully changed your sim card and now you can't get back in? just wait 15 minutes and try again ,do your services work now?also click on the down arrow on your post to edit your post delete your sim number since you are on a community web sight  that's visible to everyone
