help
02-08-2025 02:26 PM
02-09-2025 04:48 AM
Did the PIN that @computergeek541 indicated work? Please let us know.
02-08-2025 07:09 PM - edited 02-08-2025 07:11 PM
@hTideGnow wrote:if it is indeed SIM card PIN you're looking for , ask PM support to help, you can submit by direct message:
The above isn't correct. A Public Mobile customer support agent has no way to know or to check what the SIM card's current PIN is set to. Only the customer would know that, or it would be the default that I mentioned earlier. A customer support agent would only be able to provide the PUK for the SIM card, but that isn't what the customer has requested.
02-08-2025 07:07 PM
@SourDude1234 wrote:Hi, please use the following link to contact a support member for the unlock pin. Make sure to stay logged in and monitor the envelope icon on the top right. Thanks
Do you mean if the phone is locked to another carrier? I'm going to go based on the assumption that the customer has the Public Mobile SIM card in the phone. If the phone is asking for a network unlock PIN while the Public Mobile SIM card is in the device, a Public Mobile customer support agent wouldn't be able to help due the fact that would mean that the phone is locked to a different company.
02-08-2025 07:03 PM
@gecko098 wrote:SIM card number is the number on the back of the little package you got.
Sorry, but the above isn't correct. The customer is asking for a PIN, not a PUK, but even if we asusme that the csutomer asking for the SIM card's PUK, that absolutely isn't available on any of the SIM card's pacakging. To date, I have seen this fale information repeated numerous times. Unfortunately, it's not the case for Public Mobile SIM cards, nor have I ever seen the PUK for a SIM card ever printed on the packaging of a SIM card for any carrier.
02-08-2025 07:01 PM
@BEJAMIN wrote:sim card pin thanks
Unless you (or somebody else) has manually change it, the PIN number for all Public Mobile SIM cards is 1234.
02-08-2025 03:51 PM
If your phone is "carrier locked" it wont let you install a new sim if its not theirs. Carrier unlock pin is something you need to ask your old provider and they legally must do it for you. You can even go to their shop and get it done, or google it
02-08-2025 03:39 PM
What is the error message showing on your phone for the PIN?
There is a device PIN and a SIM PIN.
02-08-2025 02:38 PM
hi @BEJAMIN
you sure it is the SIM card PIN you're looking for and not the carrier lock pin?
02-08-2025 02:34 PM - edited 02-09-2025 05:53 PM
