help with phone plan
wailun
I am having issue with subscribing for a phone plan 20gb at 32$/m. please help. it is not letting me choose that option and automatically changes to 30gb plan
@wailun
The 30gb plan must be an old plan because this plan is not currently offered. Is the 20gb @ 4G for $32 Canada wide lower priced then your current 30gb plan?
The recently PM change doesn’t allow you to downgrade to a lower priced plan. Only upgrade to a more expensive plan.
AK32
Do you already have an account and are trying to change? or starting a brand new account?
perhaps try using a web browser in private/incognito mode, or by using the app as others mentioned.
hi @wailun
you are subscribing for new account?
try using the Public Mobile app to subscribe.  Download it from app store
