11-15-2020 01:33 PM - edited 01-05-2022 05:26 PM
Hi,there
I checked my account, no any talk minutes left, i also checked last 3 months usage, less 200 minutes used for outgoing call.my plan 100 minutes talk, 500 minutes Canada talk add on .I don't believe use them all, how i can check more than 3 months usage history?
thanks
11-15-2020 10:32 PM - edited 11-15-2020 10:34 PM
@honggu wrote:Hi,there
thanks
Hi @honggu yes you can check your 3 months usage history. Here's what to do
Good luck and stay safe!
11-15-2020 01:58 PM
@honggu wrote:THANKS,
I already buy 500 min talk add on, it works now.
So if you are unsure of what used up your 100....check your usage from today back to your last payment date.
11-15-2020 01:46 PM
THANKS,
11-15-2020 01:40 PM
You can't check more than 3 months of usage history unfortunately. If you don't see the 500 minute add on tracker, that means that it ran out.
The PM talk tracker is fairly accurate.
Talk
Talk minutes are counted whenever you make or receive calls on your phone. Talk time is calculated from the start of a call to when it is disconnected, and includes ring time and call routing. Total call time is always rounded up to the nearest minute. Please note that calls to voicemail and forwarding calls will use plan minutes.
Use Minutes | Doesn't Use Minutes |
Making a call | Calling *611 (the IVR) |
Answering a call (not with $15 plan) | Making or receiving calls from 911 |
Retrieving voicemail messages | Using calling apps when connected to Wifi |
Using call forwarding |
11-15-2020 01:37 PM - edited 11-15-2020 01:38 PM
You can’t. How would looking over 3 months back help you fix your issue. Try rebooting phone. I assume you have some of your 500 minute add-on available.
11-15-2020 01:35 PM - edited 11-15-2020 01:38 PM
thanks
Did you take into account seconds are rounded up to the closest minute and checking voicemail uses up minutes too?
