forgot password and security questions answer
christine99
Need to login to activate autopay
Thank you for helping
@christine99 wrote:
thank you for your help
@christine99
your welcome,
enjoy your service...
christine99
christine99
thank you
Meow
If you forgot your password to log in into your PM account, you should use 'Forgot your password' link. You will need to answer security questions, though.
If you do not answer on security question, contact CSA
To contact CSA, there are 2 methods:
- Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click here and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented.
- Send a private message to the CSA by clicking here  You’ll need to be logged into your Community account for the link to work.
@christine99
for Set up AutoPay and you will receive a $2 credit every 30 days. yes you need to login,
you can try Forgot your password visit Here link, and enter your email address,
or you need to Contact Customer Support Agent by CS_Agentand Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
    Click here to submit a ticket↗↗.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • phone number,
  • account number,
  • account 4 digit pin,
  • Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck..
