every month account gets suspended
kjoshi
Hi,
although my account is on auto-pay, every month it suspend my plan.
9 REPLIES 9
@Steamgurl  I just logged into my self service account and checked and it shows for me. Try clearing your browser history,  go to private/ incognito mode and try again to change your plan. Hitting change I immediately loses you current plans payment and immediately charges you for the new plan. It's better to change at next cycle. See article on how to do it https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
Stay safe.
@kjoshi   Generally just stay out of your account as it goes thru renewal but if your interested yhe account will change the status as it goes thru each step so you will see:
  1.  Expired
  2. Suspended
  3. Active
Unless your autopay does fail and it will stay suspended until you manually add a payment. It may go to active immediately or you may have to click on Reactivate to start your services.
@Steamgurl hi try deleting your cache reboot and use chrome in ingognito mode that usually clears up most issues f serve can a little temper mental lol
Steamgurl
I am trying to upgrade my plan to $50 to get more data but the "plan upgrade" web page doesn't show the plans? Huh?
Steamgurl
will13am
@kjoshi , has this ever led to an actual stoppage of the service?  If not, don't worry about it.  The account goes through a funky metamorphosis on renewal day.  If the service is working, don't touch, don't even look.  All will be normal by mid day.
geopublic
@kjoshi wrote:
Hi,
@kjoshi  That means that there is an issue with the credit card that you have on file. Did you get issued a new credit card? If yes, then you need to update the information using selfserve.
If the information has not change try making a one time payment of $1. If it errors out then you might submit a ticket to PM and ask them to investigate.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking  here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
gblackma
@kjoshi  as long as your services are working properly then ignore the status of your account. The normal PM renewal process is expired, then suspended, payment comes out at 2am est (on the self service account date) then the plan resets for the next 30 day cycle at 6am est. Once your phone is working properly ignore it. Just check for you 611 payment thankyou text message tomorrow.
Renewal process screenshots https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/If-I-have-a-credit-35-00-does...
If your services aren't working properly please tell us.  Stay safe.
Staliger
@kjoshi Sorry you faced this. Sometimes Autopay fails. So I personally recommend to do manual payment even with enabled Autopay. Just to prevent such suspension issues.
