10-12-2023 10:24 PM
I'm looking at traveling and would like to buy an esim for the country I am visiting. My current phone is a Samsung A13 5G. Is this esim compatible?
10-13-2023 11:32 AM
The A13 isn’t e sim compatible but you can use the top up which is more expensive but I know that the public mobile doesn’t work too good in other countries
10-12-2023 10:47 PM
@hTideGnow wrote:hi @Panino2010
A13 is eSIM compatible.
Yes, you can put travel esim there.
No, A13 does not support eSIM. It's got Dual physical SIM support.
10-12-2023 10:44 PM
A13 does not have eSIM support. Sorry, you have to buy a physical sim card. If you like, check Amazon and you can buy it ahead of your trip. But of course, you can buy it cheaper when you are there
10-12-2023 10:26 PM
