esim card purchase
12-09-2024
07:01 PM
12-09-2024
07:12 PM
computergeek541
When I attempt to purchase an esim on a new phone, I dont get an option to select a sim, so it only lets me buy a physical sim card. Also I would like to know if it would be possible to refund a physical sim card.
My Account
Phones
12-09-2024 10:33 PM
hey, according to this post, it is the font or font size. This person change the font and also turn off BOLD text, ie, change everything back to standard, and it sees the esim option
12-09-2024 10:29 PM
you can't scroll down the screen ?
12-09-2024 10:22 PM
yea I uninstalled and reinstalled and also tried tweaking with the font size options and also pinching the screen as well
12-09-2024 08:42 PM
It sounds like you have the American version of the iPhone 16. The Canadian version have SIM & eSIM.
12-09-2024 07:57 PM
it is weird you don't have eSIM option. did you try uninstall and reinstall the app?
12-09-2024 07:33 PM
@eggmangrg1 , use this link to send a private message to support to have them switch your activation to e-SIM.
12-09-2024 07:14 PM
Since I don't have a sim card slot I can't put the sim card in (iphone 16), thanks for the info on the refunds
12-09-2024 07:12 PM
@eggmangrg1 wrote:When I attempt to purchase an esim on a new phone, I dont get an option to select a sim, so it only lets me buy a physical sim card. Also I would like to know if it would be possible to refund a physical sim card.
If your phone has a SIM card slot, your current Public Mobile SIM card can be used in your new phone. Unfortunately, there are no refunds on SIM cards.
