07-02-2025 03:45 PM
I just purchased the $29 a month plan this afternoon, but the eSim is not working on my phone. It is a Google Pixel 8, and when I put in the IMEI info, Public Mobile said it was compatible.
When I go to connect to my data it just says "no connection" and that my eSim is unavailable. The really frustrating thing is that I can't even log into my account because it wants to send a verification code to my new phone number, which I can't access because the eSim isn't working.
I've tried restarting my phone multiple times, reinstalling the app, and resetting network settings but nothing seems to have worked. Any suggestions?
07-02-2025 05:53 PM
Hi there. I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
07-02-2025 04:01 PM
hi @malia_kirk that might not be an eSIM compatibility issue
is the PM eSIM installed in the phone already? make sure the old sim card is removed or old eSIM is disabled. Then make sure PM eSIM is enabled and set as Primary, try Reset Network Settings
if still fails, PM support agent can help. you can submit by direct message:
07-02-2025 04:01 PM
Yes, I did. I'll try reaching out to an agent.
07-02-2025 03:59 PM
Did you remove your previous eSIM? Reach out to agent for help at the link below.
