12-10-2023 11:53 PM
Hello,
I will be traveling to Thailand for roughly a month and will be using and installing an eSim service for data abroad. Will this affect my current public mobile subscription in any way? Or will it be unaffected?
12-11-2023 12:22 AM
@Handy1My public mobile subscription is on a physical sim card slot. I'll be using a digital eSim over there when I arrive.
12-10-2023 11:58 PM
@WilliamMoo25 Is your public mobile on eSIM or physical sim if physical SIM card then no if eSIM id consider just buying a pre paid SIM card in Thailand . And note PM sim wont work there PM only has roaming in the US
12-10-2023 11:56 PM - edited 12-11-2023 12:15 AM
It will be unaffected. Your PM SIM will not work there so you will be dependent on the eSIM
Edited to add: Handy1 has a very valid point about it depending on if your PM sim is an eSIM
