eSIM
Caro11
I activated my eSIM and it didn’t work. It seems now I deleted it, how do I reinstall it?
Meow
Great 😞
Now go and buy physical SIM instead.
HALIMACS
@Caro11
 you deleted it?
@Caro11 you shouldn't delete it.  Please check again on the Sim Manager screen, or Settings >Cellular and see if the esim is there.
Usually, you have to pay $5 to re-buy a new esim if you have deleted it, but since it is a new activation, maybe support staff can help.  Please message them and see if they can generate a new one for you:
