eSIM won’t activate
Peter02
Hi, I can’t activate my eSIM. When I was setting up my account I wanted to transfer a phone number, followed all the instructions, got the SMS verification, replied YES to verify, my previous provider disconnected my account but I cannot activate my eSIM. How do I contact someone?
12 REPLIES 12
@Peter02 wrote:
Is there a way to get a refund since public was not able to provide the service?
You'll need to discuss privately with the Public Mobile customer support agent who you'v been communicating with.
Peter02
CSA_PM
Customer Support Agent
Thank you for the escalation! The customer is in contact with an agent.
@Peter02
I have escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
Peter02
Tried that. Nothing
@Peter02  Maybe try logging out and clear cache and cookies and use a new web browser window to log back in and try to resubmit ticket might help
Peter02
Ok thanks for trying anyway. I’m unable to submit a support ticket… I fill out the fields but nothing happens when I hit submit.
@Peter02  No I don’t belive so , only thing that really matters is that the credit card matches that of the postal code you used to create account . People can change numbers or move to different provinces without worry . . You just have to keep checking your community in box for supports reply is you have already submitted ticket for further assistance or maybe some other community memeber has better idea . Best of luck
Peter02
I don’t see the public eSIM listed there. I tried all those things.
could it be that I’m trying to transfer an Ontario number and I selected NB (New Brunswick) as my region when I made my account?
@Peter02  If you check your phone settings sim manger . Do you see the public mobile eSIM there listed ? If so ensure it’s set to primary or if iPhone you toggle on switch that says “turn this line on “ and remove old carriers sim and reboot the phone or reset network settings and see if that helps clears things up for you
Peter02
I already sent a message to CS_agent. I also tried to submit a ticket but the submit button didn’t work. I tried loading the page again but I kept on receiving at 404 error that the page is unavailable
@Peter02
send  a  private message   To CS_Agent
