01-28-2026
07:16 PM
01-28-2026
08:14 PM
computergeek541
Hi
i signed up with public mobile and eSIM didnot activate on my phone so I deleted it. I went and bought a physical sim. Now when I try to do a sim swap it sends a otp on the phone number which I can’t access because it’s not working. Can you help me do the sim swap to a physical sim I bought ?
01-28-2026 10:18 PM
@Haspi wrote:Hi
i tried that but it didn’t give me the option to send code to email when doing a sim swap
I read somewhere that you need keep doing it for 3-4 times
01-28-2026 09:06 PM
Hi
01-28-2026 08:07 PM - edited 01-28-2026 08:10 PM
Hi,
Are you trying to do the SIM swap through the app? and your not able to log in because it's asking for a code sent to your phone. If so, try logging into Public Mobile on a browser instead. Go to the website and sign in — it’ll ask for the OTP sent to your phone, but you can click “Didn’t receive the code?” and choose the option to have the code sent to your email instead.
01-28-2026 08:04 PM
hi @Haspi
yes, your account was not fully setup yet, so you need a PM agent to update the sim card for you instead.
ask PM support agent to help, you can submit ticket by direct message:
