01-23-2026 10:37 AM - edited 01-23-2026 10:38 AM
I have a number that was originally from Public Mobile, then I moved to a Chatr plan, and now that I’m trying to move it to Rogers the transfer isn’t working because the provider has a protection on the number, and the provider is listed as Telus. I have contacted Telus, no use. Chatr and Rogers can’t figure it out either.
Any help would be greatly appreciated!
01-23-2026 10:46 AM
Thank you, I will try that!
01-23-2026 10:41 AM
PM does not have any "number protection" set on any number. I don't think PM can help at all
but you can ask PM. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
