02-23-2024
08:39 PM
02-23-2024
10:57 PM
computergeek541
I got a message it did not activate. I tried scanning the QR code no luck.
02-23-2024 08:43 PM
@Dman_dg can you check the Sim Manager on the device (or Settings > Cellular) first and see if the Public Mobile eSim is there already and just not enabled?
if not there, then yes, you really need to engage support by direct message for further help
02-23-2024 08:42 PM - edited 02-23-2024 08:43 PM
If you download the public mobile app and followed the directions and still not working send a message to cs agents at the link below to advise.
