eSIM activation
Qinnuayuak
I’m having issue with the eSIM activation, I can only use wifi-calling since I live where we have no cell service.
who can turn wifi-calling "on" on your end so I can receive SMS texts messages via wifi-calling?
thx
RavingRaven
@Qinnuayuak
According to this thread wifi calling may be coming sooner than previously thought:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Wifi-Calling-good-news/td-p/1219698
However that doesn't really help you at the moment. Assuming you have an Android phone try enabling RCS (Chat features) in your messaging app. RCS uses mobile or wifi data. This may help you overcome the issue of recieving the verification code otherwise you will need to get within cellular range to recieve the code.
Are you in Canada's North? I know Bell recently signed new partnership agreements to expand coverage and infrastructure with NorthSixtyUnity whose aquistion of NorthWestel will make them the largest Indigenous owned telecommunications provider globally. Telus and Bell have network sharing agreements so you will need to be within range of any cell tower in the North if enabling RCS does not work to recieve that one all important verification text.
Otherwise opting to wait for a physical Sim card sent "care of" a trusted friend or family member in cellular range who can put the Sim card in their phone when you activate and send you the verification code for account access and then send you the Sim card.
EB0
Public mobile doesn’t have WiFI calling right now, no one knows when it becomes available, may be months or years.
Better looking for another provider that works on your area.
Freedom mobile is the cheapest provider that has WiFi calling
@Qinnuayuak there is no wifi calling at the moment.. may come soonz but not now 😞
