eSIM Activation
Cornelius76
I can't activate my esim to my s20
8 REPLIES 8
hi @Cornelius76
this is still the community you are replying
please message PM support (CS_agent)  directly using this link
Cornelius76
Can you help me activate my sim card I put the number down and payment but can't activate it and choose to keep my phone number? And you took 2 payments from my account
hi @Cornelius76
reply with CS_agent on your community inbox and ask them to help you to update the sim card number for your.  Also, they will reimburse you the extra cost and you won't pay twice
Community inbox:  https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Cornelius76
Why does it tell me something is wrong when I but a sim card number in and payment and can't go anywhere with it ? And you took 2 payments from my account and I can't install the sim card to my Account I bought it through Amazon the sim card
CSA_PM
Customer Support Agent
Hi there, I’ve looked into it and see that the issue was already handled by another agent.
@Cornelius76 support agent can arrange that.  Ask them to let you buy a PM sim card from nearby Telus or Koodo store or Amazon and reimburse you for the cost
Please use the link above to message them
(Im fact, I have helped to escalate the issue as well, monitor your Community inbox)
Cornelius76
Ok so can you send me a sim card
@Cornelius76 there have been some reports about issues with activating esim in S20. please check with PM support directly .  Private message CS Agent at:
