eSIM Activation
Wendy25
Hello, I just downloaded the eSIM using QR code, but having trouble with a status that's stuck on "activating"...
2 REPLIES 2
hi @Wendy25 try reboot the phone and see if it helps
if not, you will need to message support agent for help
@Wendy25  let support help you
send  a  private message   To CS_Agent
