05-07-2024
08:10 PM
05-08-2024
02:12 AM
computergeek541
Hello, I was unable to complete my e-Sim activation when it was first being setup in the app. I have also tried using the QR code provided in the e-mail, but it says activation failed on my iPhone cellular setup. I have tried restarting my phone, and the service bars is showing as SOS since my phone number has been transferred.
Joining Public
05-07-2024 10:14 PM
Hi everyone, thanks for the advice. They got back to me and it was a glitch with the initial activation of the eSIM and it acted as if it had been deleted which is why the QR code didn't work. I had to get a new eSIM and everything worked after that.
05-07-2024 10:07 PM
Katie I’m not a hero but just subscribed tonight and had the exact same issue. Ported my number from Bell and called to confirm it was ported the phone still didn’t work. I had the same issue esim not activated. iPhone XR is what I have. I powered down and remove my SIM card from Bell. When I powered it back up shwing !!! All up and going calls in and out texting no issues now good luck
05-07-2024 08:19 PM
There is no eSim listed on my phone. I have tried the QR code from the welcome e-mail, and I get "Unable to Activate eSIM" and to contact my carrier for assistance.
I have opened a ticket with CS Agent, but have not yet received a response.
05-07-2024 08:15 PM
I am assuming that you will need to contact CS_Agent, have you used your QR code already?
It looks like this within the Welcome Email:
If you already tried it, please check your phone within the Cellular settings and see if it is enabled, also make sure to disable any PM non eSIM:
On your phone's cellular screen press on "Public Mobile" menu
And disable any non PM eSIM / SIM like this BetterRoaming eSIM:
Switch it off like here:
Then enable PM eSIM:
Then enable PM eSIM via toggle:
It should start to work. iPhone XR, XS, XS Max, and iPhone SE2 and newer are eSIM compatible.
But if it doesn't work or you removed / deleted the eSIM from your phone please contact CS_Agent for a new eSIM:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
05-07-2024 08:11 PM
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually)
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
