05-07-2024 10:20 PM
Just arrived in Las Vegas Nevada and I switched my subscription to the $34 a month Canada and us data 50 gigs 5G speed but I only have a 4G phone. and I don't have any data in Las Vegas? Someone help please
05-07-2024 10:22 PM
4G phone is LTE and it works for US roaming
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter. Also confirm your network mode to 4G or LTE
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
