dropped calls
bcablewilliams
why am I having a lot of dropped call
2 REPLIES 2
hairbag1
@bcablewilliams
depending on your location, you could be experiencing issue with your calls due to VoLTE not being available on your cellphone. If you let us know the make / model, maybe we can provide some suggestions.
Chalupa_Batman
What phone do you have? I have a feeling I know which. S20?
Go into your settings, then Network Settings and reset them. Then reboot your phone. This SHOULD fix them. If you're still getting dropped calls, reach out to a CS Agent and get them to reset on their end.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
