dropped calls
cc2024
Is anyone having frequent dropped calls in Thunder Bay ON?  I only have 1-2 bars of cell service at home.  Calls are dropping more often than not.
7 REPLIES 7
sheytoon
Bell and Telus coverage isn't the best there. Bell has no 850 MHz spectrum. It would be better to stick with Rogers or TbayTel if that works better for you.
cc2024
I've tried that.  It's a new iPhone.  The problem isn't my phone.  My previous provider Tbaytel had 3 bars minimum of service in my home.  Never had dropped calls.  Is this a common problem with Public Mobile?
@cc2024  Can you try the SIM card in another phone to test ?
cc2024
it doesn't make a difference.  Still only 1-2 bars of service in my home.
cc2024
How would that help?  I'll try it
@cc2024  Not the best solution but try phone set to 3G and see if the helps with voice
