deleted
Boxe222
deleted
Hi @HALIMACS no, OP was asking how to change email
Boxe222
srry 😅
I deleted it after the robot told me where to go
HALIMACS
I love a mystery, @Boxe222
Maybe check your trash bin??
hi @Boxe222 you don't need to delete your original post...
hi @Boxe222 only PM cs agent can help to change email address used on My Account.   Please open ticket with them, follow my steps below for quicker reply
at : https://publicmobile.ca/chatbot.
     First type Forgot Login,
@Boxe222 @To change your email you need supports help
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
