[deleted]
tomato22
2 REPLIES 2
golfball
The amount of tax you are charged is based on the phone number. So unless you change to an Ontario number you will be charged Alberta tax.
ORNGNBLK
@tomato22  Sounds like you’ve troubleshooted a bit.  The card from which you are paying, and your updated address in PM, must match exactly, so if you moved, you may need to consider that. (Ex: If there’s a suite # or apt # before your address, it can’t be entered after)
Hope this helps
*Edit-  I just encountered an error myself, and think that the system is down temporarily. This could be a matter of time before it resolves itself.
