05-14-2022 05:47 PM
I just received the phone and activated yesterday and nothing happened, dead ?
Service
05-14-2022 09:27 PM
Could you give us more information?
Is the phone not working or is it the SIM not working?
Did you port your old number over to PM?
Did you power off your phone before putting the SIM in your phone?
05-14-2022 07:08 PM
Hi there, some more details/info will help the community to point you in the right direction
05-14-2022 06:22 PM
Where from you receive your phone? Did you buy it from PM?
Find another working SIM and try it in the phone to see if phone is working at all.
Check your account to see does it say Active.
Did you follow all steps to active PM SIM and get a new number?
Try your PM SIM in another phone to see if you have service at all.
05-14-2022 05:50 PM
@addition it is a phone you got it from PM? It didn't even power up?
if you can power it up, try with another active sim card
if nothing works, don't wait, open ticket with PM Support for full refund
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
05-14-2022 05:48 PM
@addition wrote:I just received the phone and activated yesterday and nothing happened, dead ?
Phone purchased from PM? If yes, here is the return/warranty info:
https://www.publicmobile.ca/en/bc/get-help/articles/phone-warranty-returns-repairs
