01-16-2020 03:36 PM - edited 01-05-2022 09:03 AM
01-16-2020 06:17 PM
Uninstall any unused apps and have apps only update on WiFi. Use WiFi whenever possible to download, stream, etc.
01-16-2020 04:31 PM - edited 01-16-2020 04:33 PM
If you have an Android also check if your phone has Wifi+.
If it does. Turn it off!
01-16-2020 04:27 PM
Please check data usage On your device.
Check settings to make sure that you are not boosting your WiFi signal with your data signal.
You also have an option of restricting background data for each app so that those apps are forced to do most of the maintenance exclusively on WiFi signal.
Which plan are you on?
01-16-2020 03:55 PM
@satifollmer2020 Do you use an iPhone? If so, be sure WiFi Assist is OFF. (Settings >> Cellular: scroll to the bottom of the page to find it)
01-16-2020 03:50 PM
Log into your account and click on view usage.
Here is more info about managing your data.
https://www.publicmobile.ca/en/bc/get-help/articles/managing-your-data-usage
01-16-2020 03:43 PM
Yeah, @geopublic has it right, i.e. there's just WAY too many data leaks in cell phone apps.
So, @satifollmer2020 how much data are we talking about, i.e. how much is allotted to your plan?
01-16-2020 03:39 PM - edited 01-16-2020 03:44 PM
@satifollmer2020 wrote:i spent almost all the time connected to the wifi and i got a text sayng i used all my data. that's unreal. i did everything the robo wanted me to do and it did not work
@satifollmer2020 Are you sure you were on WiFi? It's best to go through the settings of each App and make sure to select the option of updating only on WiFi. Same goes for system updates and backups.
