04-16-2019 12:52 PM - edited 01-05-2022 04:25 AM
04-17-2019 12:11 PM
@cavemantoronto wrote:
@truckkarr wrote:Never have been so dissapointed in a cell company terrible net work
Which network do you think is good? There really only is Bell, Telus, Rogers, Freedom, Videtron, and smaller regional companies. Network at Public is one of best and uses Telus.
Every network (even the big 2.5) has areas where it is great and areas where it is weak. It's virtually impossible in a country like Canada (probably almost any country) to get 100% coverage with no weak/dead spots/areas and enough available capacity for every possible use at any time. Even if you're on the "best" network in Canada (always a bit subjective, and contentious title), if you frequent area(s) of weak reception, you're going to think it's awful; likewise, even if you're on the "worst" network but frequent areas of particular strength, it's going to be a great experience.
TLDR; there's no "one-size-fits-all" network, so you really need to experiement to find one that works well in the places in which you spend the majority of your time.
04-17-2019 12:49 AM - edited 04-17-2019 12:49 AM
04-16-2019 02:37 PM
Don't mad, just post your problem and someone include me will be happy to help.
04-16-2019 02:20 PM
@truckkarr, please do tell....
04-16-2019 02:13 PM
PM is owned by Telus & operates on the Telus network.
If you've choosen a data plan on 3G and you we're on LTE before; you may notice a difference, especially with streaming video. If this is the case; maybe try one of PM's LTE plans instead.
04-16-2019 12:59 PM
Are you coming from Rogers? This network is Telus' Network. Largest in Canada. Same as Bell as well.
What is happening?
04-16-2019 12:58 PM - edited 04-16-2019 01:06 PM
@truckkarr Odd, this is telus/bell, which is the best network in Canada. Are you sure its the network? Can you give more details? What exactly is the problem and where exactly do you have this problem, everywhere or in a specific place?
