09-24-2023 07:30 PM
09-24-2023 09:57 PM
Thank you all for verifying that sms still works when data runs out.
09-24-2023 08:59 PM
Yes @DAnne1 Switch it to SMS and it's free! Just know that iMessages use very little data though.
09-24-2023 08:55 PM
@DAnne1 yes that’s correct , you can send sms no extra charge
09-24-2023 08:52 PM
Just to be sure, if I click on 'send as SMS'
on my iPhone, it states carrier messaging rates may apply. So I imagine that means it passes as PM regular messages, no charge?
09-24-2023 08:29 PM
SMS and calling are completely different from data.
Even when one has exhausted their data, they can still utilize MMS (i.e. picture messaging) and RCS (i.e. Apple iMessage and Android chat) by using Wi-Fi.
09-24-2023 07:42 PM
Yes, you may still receive “green messages” or SMS messages!
09-24-2023 07:33 PM
@kaostream1 Yes
09-24-2023 07:31 PM
Hi @kaostream1
Of course. However if you have the iPhone then iMessage needs data. Therefore go into your settings and change to SMS instead so it still works.
