11-21-2022 08:24 PM
paid $35 on 18th, added $15 after, almost out of data? $50 for 2 days?
My Account
11-21-2022 08:41 PM
11-21-2022 08:30 PM
HI @guyc did you try to clear cache first and then restart browser to check the usage again?
or try to use Private/Incognito mode to check?
11-21-2022 08:28 PM
Click any little spinner refresh icons you see lower down to make sure you're seeing recent information. Or use private mode.
This is not pay as you go in case you're thinking adding money does anything. Adding money is only good for buying add-ons or for renewal.
Do you have a data limiter setting set on your phone?
11-21-2022 08:28 PM - edited 11-21-2022 08:32 PM
What plan are you on?
To see an accurate count of your data usage clear your browser cache and history and open a new browser in incognito. There is also the 15GB for $40 or $45 for 20 GB if you are burning through too much data. Make sure your apps are not using data in the background.
11-21-2022 08:27 PM - edited 11-21-2022 08:30 PM
@guyc How do you know that you're out of data? Did you get a text from PM about your data or can't you log onto any websites anymore?
