data plans
Greg1957
What happened to the 4G plans?
I only saw 1 for $60.00!
Guess I will not be with public mobile for much longer!!!
ChuckYeah
@Greg1957 If you have a 4G plan now you are grandfathered so unless you need a different plan, you're ok for now. Honestly, on your way out, you might want to try a 3G plan. Lots of savings and very little difference for MOST users.
darlicious
@Greg1957  What do you want to use the 4G for? Are downloading or streaming HD?
The $60 plan does not provide high speed LTE data.
Triguy
All the plans are 3G except the 1GB data only plan which is 4G.
dabr
There is only one 4G plan which is the $30 1GB data only plan.  The only other 4G plans would be what were offered earlier and are grandfathered in for customers with those plans.
