05-09-2023
11:14 PM
05-16-2023
10:02 AM
Dunkman
My daughter's data is being used up at odd hours of the day, and seems to be used when she is not even using her phone. how do I make sure that her phone isn't using data when it can be using wifi. my other daughter hasn't even used any data and they started their plans at the same time.
05-10-2023 06:40 AM - edited 05-10-2023 06:41 AM
Aside from public mobiles posting of data in 12 hour increments, as well as ensuring background apps and Wi-Fi assist are not running, there's also the possibility if there is a hotspot set on the device others could be using the data.
Check to make sure there is no hotspot enabled
05-09-2023 11:37 PM
@lanaG1 wrote:My daughter's data is being used up at odd hours of the day, and seems to be used when she is not even using her phone. how do I make sure that her phone isn't using data when it can be using wifi. my other daughter hasn't even used any data and they started their plans at the same time.
Public Mobile's usage history for the account doesn't show the time of day that data is used. It only summarized the total data usage twice a day in the more detailed results.
05-09-2023 11:36 PM - edited 05-09-2023 11:37 PM
some phones do their "updates" at night.
Turn OFF data to apps that aren't used on a regular basis.
added..
disable Wifi Assist
